Ho SU 2014 quando clicco su un file non sul dekstop sketchup mi da il seguente errore: come mai? un bug?
Error: #<LoadError: cannot load such file – rexml/document>
c:/users/mauro/appdata/roaming/sketchup/sketchup 2014/sketchup/plugins/oldbridgesoft_steelsketch/create_profile.rbs:13:in require' c:/users/mauro/appdata/roaming/sketchup/sketchup 2014/sketchup/plugins/oldbridgesoft_steelsketch/create_profile.rbs:13:in
c:/users/mauro/appdata/roaming/sketchup/sketchup 2014/sketchup/plugins/oldbridgesoft_steelsketch/loader.rbs:17:in eval' c:/users/mauro/appdata/roaming/sketchup/sketchup 2014/sketchup/plugins/oldbridgesoft_steelsketch/loader.rbs:17:in
require’
c:/users/mauro/appdata/roaming/sketchup/sketchup 2014/sketchup/plugins/oldbridgesoft_steelsketch/loader.rbs:17:in <main>' C:/PROGRA~2/SketchUp/SKETCH~1/Tools/extensions.rb:197:in
eval’
C:/PROGRA~2/SketchUp/SKETCH~1/Tools/extensions.rb:197:in require' C:/PROGRA~2/SketchUp/SKETCH~1/Tools/extensions.rb:197:in
load’
C:/Users/Mauro/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/OldBridgeSoft_SteelSketch.rb:12:in register_extension' C:/Users/Mauro/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/OldBridgeSoft_SteelSketch.rb:12:in
module:SteelSketch’
C:/Users/Mauro/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/OldBridgeSoft_SteelSketch.rb:6:in <module:OldBridgeSoft>' C:/Users/Mauro/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/OldBridgeSoft_SteelSketch.rb:5:in
<top (required)>’
Error Loading File C:/Users/Mauro/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/TT_Lib2/core.rb
Error: #<LoadError: cannot load such file – fiddle>
C:/Users/Mauro/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/TT_Lib2/win32_shim.rb:3:in require' C:/Users/Mauro/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/TT_Lib2/win32_shim.rb:3:in
<top (required)>’
C:/Users/Mauro/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/TT_Lib2/win32.rb:26:in require' C:/Users/Mauro/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/TT_Lib2/win32.rb:26:in
module:Win32’
C:/Users/Mauro/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/TT_Lib2/win32.rb:12:in <top (required)>' C:/Users/Mauro/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/TT_Lib2/debug.rb:10:in
require’
C:/Users/Mauro/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/TT_Lib2/debug.rb:10:in <top (required)>' C:/Users/Mauro/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/TT_Lib2/core.rb:505:in
require’
C:/Users/Mauro/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/TT_Lib2/core.rb:505:in block in <top (required)>' C:/Users/Mauro/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/TT_Lib2/core.rb:500:in
each’
C:/Users/Mauro/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/TT_Lib2/core.rb:500:in <top (required)>' C:/PROGRA~2/SketchUp/SKETCH~1/Tools/extensions.rb:197:in
require’
C:/PROGRA~2/SketchUp/SKETCH~1/Tools/extensions.rb:197:in load' C:/Users/Mauro/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/TT_Lib2.rb:40:in
register_extension’
C:/Users/Mauro/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/TT_Lib2.rb:40:in <module:Lib>' C:/Users/Mauro/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/TT_Lib2.rb:14:in
module:TT’
C:/Users/Mauro/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/TT_Lib2.rb:13:in `<top (required)>’
